Controls Menu
First post, by drsassafras
Hi
Could Dosbox Features Such as Screen Capture, Video Record, basicly everything you see at http://www.dosbox.com/wiki/Special_Keys be placed into a menu beside the file menu? They could be clicked manually, & can also serve as a reminder of what options are there and the keyboard shortcuts.
I think it would make dosbox easier to use & would cut down on the learning curve it takes to use DosBox effectively.
Reply 4 of 15, by MiniMax
Rank Moderator
Moderator
wd iz ze devil
_________________
Reply 6 of 15, by drsassafras
After searching for several hours on the SDL website, & viewing many SDL tutorials, I still don't see any way to manipulate the GUI. Everything I see has the code compiled like an old application would have such as in dos, or in some non-visual language. Can you direct me to the visual part of this?
Reply 7 of 15, by MiniMax
Rank Moderator
Moderator
http://news.bbc.co.uk/2/hi/health/4566319.stm
_________________
Reply 10 of 15, by Qbix
Rank DOSBox Author
DOSBox Author
you didn't waste your time. You only didn't realize that if it was really simple we would have done ages ago.
Water flows down the stream
Reply 11 of 15, by drsassafras
Sometimes I don't know with you guys. I feel as though I get more comments making fun of the fact that I am new to dosbox than I get comments that would help me become more familiar with it. I suppose it could be something else I don't understand about the behavior of the experienced members of this forum. This thread is not the only example. I get the feeling that I am not wanted here. I think (with the only exception of Fryslan's post) I have finally got the general idea. goodbye.
Reply 13 of 15, by drsassafras
I suppose I was not clear in my post. There is in fact no "file" menu in dosbox. I have included a screen shot for the sake of clarification.
My comment should have talked about adding another menu beside the window menu in dosbox that would allow the keyboard shortcuts (such as frameskip, & screen capture) to be accessed via the menu. It could also serve as a reminder to all those who do not have the keyboard shortcuts memorized to heart.
The menu might be called "function" or "actions" or something.
I don't see how DSGL could do this, it really seems to me as though it would need to be implemented in DosBox.
At this point I am unsure if my initial comment was too specific (and with some false information in it) for it to be understandable.
    83.56 KiB
    Screenshot of me with the open "window" menu in DoxBox.
Reply 14 of 15, by rcblanke
Well, a lot of hard work has already been invested by Moe, Kippesoep and others to write a cross-platform solution by implementing a front-end/User Interface inside DOSBox to alter settings. Might make sense to also include tools to the features that you talked about. Still, the UI is a complex thing and might take quite some time to finish before it is integrated into DOSBox.
