First post, by iceborg01
iceborg01
Offline
Hello,
(Sorry if my english is not the best, I am from Germany)
I use DosBox 0.73 on WinXP Pro.
I tried to install System Shock 1 (SVGA).
(I've got the original CD)
So I mounted a directory on Drive C
mount c c:\ssh -freesize 1000
and an CDROM
mount d d:\ -t cdrom -label SYSTEM
and I also tried it from the harddisk after I copied
the CD onto the harddisk
mount d c:\ssh\sshcd -t cdrom -label SYSTEM
But in every case it says:
Please run install from base directory of the CD
What can I do?
