First post, by Hanif
When I open big LOTUS123 files, and I press F9 to calculate it freezes up the application. However, I am able to successfully press F9 with smaller spreadsheet files in Lotus123 for Dos.
When I press F9 to calculate on the big files, it seems to hang with the WAIT. I left it alone for about 5 minutes and it actually completed but why does it take so long?
When I launch the application through DOSBOX, Cpu Cycles: 3000, Frameskip: 0, and Maximum memory size is 63MB. I am thinking I will need to change the 63MB so that its higher but my settings below have it to 2048MB....???
Cpu Cycles: 3000
These are my settings:
language=
machine=vga
captures=capture
memsize=2048
core=simple
cycles=auto
cycledown=20
xms=true
ems=true
umb=true
