First post, by Hanif
I have a Brother laser printer connected by LTP1 > USB > PC. Windows XP can print fine, however, Lotus123 is unable to print to the printer.
I tried this command net use lpt1: \\antec\BrotherM /persistent:yes to map the printer to an emulated local port that DOS know about (e.g. LPT1). No cigar.
Any suggestions would be great.
Reply 15 of 15, by Hanif
status window:
Copyright 2002-2008 DOSBox Team, published under GNU GPL.
CVS build compiled on Sep 2 2008 - http://home.arcor.de/h-a-l-9000
featuring:
Try not to exit on unsupported fullscreen mode
\a bell support
Soundblaster reset fixes for demos using STMIK
Make the cycles 'fixed' expression optional
Add the 'IMGMAKE' command (creates disk images)
Make vgaonly features availible to other graphics cards - see [render]
Add DATE and TIME commands, midnight overflow, and host time synchronization
NE2000 Ethernet passthrough
OPL chip passthrough
Parallel Port passthrough and Virtual Printer patch, logging enabled
Quit on reboot instead of lock/crash
Serial FIFO support and logging capability enabled
Increase maximum resolution to 1600x1200, add lot's of highres VESA modes
Fixes to S3 resolution handling, enable LDGFXROM
Fix text mode panning in vgaonly modes
CONFIG:Loading primary settings from config file C:\Program Files\DOSBox_MB4\dos
box.conf
MIDI:Opened device:win32
WinPcap has to be installed for the NE2000 to work.
