First post, by thrush
Hi When i try to mount Daggerfall as a cdrom using this command from the bethesda site
mount d c:\dosgames\dfcd -t cdrom -label daggerfall
I get in return
MSCDEX mounted subdirectory limited support
then when i try to load daggerfall it tells me that i have inserted the wrong CD and must try again
I was wondering if anyone else here has had that problem and had a solution to the problem
all help greatly appreciated
Thrush
Reply 2 of 5, by MiniMax
Rank Moderator
Moderator
You can't fix stupid.
_________________
Reply 4 of 5, by MiniMax
Rank Moderator
Moderator
If bet if you upgrade to DOSBox 0.73 it will work.
_________________
Reply 5 of 5, by HunterZ
"MSCDEX mounted subdirectory limited support" is a normal message when you mount a directory on your hard drive as a CD instead of mounting an actual CD-ROM drive. It will not prevent Daggerfall from installing. Make sure you're using DOSBox 0.73 and that you are following the Daggerfall install instructions TO THE LETTER.
