First post, by lastthai
first i install waterworld the quest for dry land in
d:\intrplay\ww
then i click water.exe in that folder
the game run well
after i complete mission one
game quit so i hit
water.exe again and this time they send me to mission 2 briefing(continue from last game)
when i start the mission 2 the game quit
so i try to use dos box this is what happen
http://upic.me/i/eo/trouble.jpg
after this i can't even run game by double click at water.exe
i don't know what to do now
T-T
thx
ps.my dosbox run well with abuse,celtic tales,wwf
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
the error is that it can't find a certain file.
Maybe install the game inside dosbox and use the same mounting as when you installed the game ?
Water flows down the stream
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
