Wish for SDL 1.3 support
First post, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
As I'm on a mac these days and foolishly updated to OS X 10.6 all three of the open source programs I compile myself have become uncompilable...
Top reason is that SDL 1.2.x is not compatible at all to OS X 10.6 anymore and needs a lot of fixes that might never actually land on its branch...
SDL 1.3 compiles fine but Dosbox' configure doesn't allow building with it.
Since the both SDLs are not exactly compatible I guess support for 1.3 in Dosbox will be far away, but one can dream (and rant) 😀
Reply 3 of 14, by wd
Rank DOSBox Author
DOSBox Author
Oh i feel the need to reply 😉
Sadly the SDL people switched to 1.3 development (which still is in beta
stage yet said to be "quite far"), leaving 1.2.x more or less as-is which
still is not in a too nice state.
Anybody got some experience with api compatibility (how to port)? As there
should be co-existence unless 1.3 turns out to be the god of backends.
Reply 4 of 14, by Dominus
DOSBox Moderator
Not the answer I expected 😀
I'm not sure whether 1.3 will ever leave beta and I'm also not sure whether 1.2x will ever evolve 😀
Right now, OS X 10.6 is the only real show stopper for SDL 1.2.x, just maybe it will be enough motivation for more OS software to be 1.3 compatible... Right now it is a real mess 🙁
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 14, by wd
Rank DOSBox Author
DOSBox Author
I've only followed 1.2.x development, yet there are some messages where
they preferred to not break 1.2.x api compatibility when discussing some 1.3
stuff. Still might be a lot work to switch, dunno.
Reply 6 of 14, by Pickle
We have been doing some work on the pandora/wiz with SDL 1.3, I havnt spent a ton of time with it, but there is a new API in 1.3 that will work better in getting windows for OPENGL/OPENGLES, basically its a best API that can cover more systems and arch's.
I believe it would be in the best interest that dosbox reworks to support the new API, as it would allow more systems to have hw accelerated rendering. Although it may not be a good idea until the SDL team gets closer to an actual release.
As far as I can tell though SDL 1.3 still has the old API functions in it, that may be for now. I dont know if they will be removed later or not.
Also at least on linux systems SDL is setup through sdl-config, does MAC systems have the same thing? If can change that then you can point to any SDL you want, or even change the makefile after its been generated.
Reply 8 of 14, by Pickle
As far as I know it wouldnt since 1.3 should be backwards compatible with 1.2, for dosbox to be everything to all people its possible 1.3 code could be preprocessed out depending on the version of SDL detected.
But thats if dosbox adds 1.3 only API. I dont see any reason why the 1.2 code shoudlnt work on a 1.3 library.
Reply 9 of 14, by Dominus
DOSBox Moderator
Switching straight to SDL 1.3 probably will need some coding. Not everything is compatible, even though mostly it needs small changes.
I ran into this, when I tried to compile Pentagram (http://pentagram.sf.net) with SDL 1.3. Some ints needed to be long ints, others size_t and then compiling broke on another SDL problem...
Oh, and there is actually movement on the SDL front http://bugzilla.libsdl.org/show_bug.cgi?id=581
Reply 11 of 14, by leileilol
DosFreak wrote:
Would using SDL 1.3 limit older OS support?
I sure hope not as I do use DOSBox on my 9x machines for covering the CGA speed gap.
long live PCem
Debian's fucked
Reply 12 of 14, by wd
Rank DOSBox Author
DOSBox Author
There surely should be the possibility to compile against both library versions.
Reply 13 of 14, by wd
Rank DOSBox Author
DOSBox Author
Anybody who's interested to work on this please let me know.
Reply 14 of 14, by Dominus
DOSBox Moderator
A status update for OS X 10.6.1:
SVN of SDL 1.2 is compiling now, as well as SDL_Sound, Dosbox needs a little patch in src/gui/midi_coreaudio.h so it #include <CoreServices/CoreServices.h>
Then Dosbox won't compile because of several bitu whatever errors, I'll report more some other time 😀
And probably need to go to another thread for this 😀
Should I file a tracker report for the missing include? (this include do several other projects miss as well, btw, so it is standard problem/solution by now 😀)
