First post, by jpe30
So I have Blood up and running great, it runs smooth and without any problems. Except, every time I try to save, the game crashes. Any suggestions on how to fix this?
Reply 1 of 6, by Igracek
Which version have you? I'm using One Unit: Whole Blood ( 1.21) version of Blood from CD image and saving works fine. (Vista x64 + DOSbox 0.73)
But I have another question. Is it normal in Blood, that Redbook audio level music is played only once and after that is quiet until you complete the level? I'm not sure if it is problem of Blood or DOSbox.
Reply 2 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
it seems to be a dosbox problem, but I never played blood long enough for an audiotrack to finish
Water flows down the stream
Reply 3 of 6, by eL_PuSHeR
I finished One Unit: Whole Blood (1.21) two months ago using DOSBox 0.73
Must be version dependant.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 6, by SwissCM
I too finished One Unit: Whole Blood a few months ago without a problem. Cryptic Passage didn't have any issues either, saves worked fine on both.
You're a sad, sad person Qbix.
Reply 6 of 6, by lightmaster
yup ask there hehe
