First post, by Ikaragua
Hello.
I succesfully installed Action Soccer in the DOSBox (0.73), while having verified the sound functionality durch the installing process as working. Nevertheless as soon as I start the main game ("play") rasping sounds are being put out and the game crashes. Also trying to change the sound options proved to be not possible, as the install procedure crashes too.
I tried to solve the problem by changing the xms, ems and umb support and by playing via cdrom emulation and image mounting.
What can I do to get it running?
Thanks in advance!
