Terminator 1990 crashing
First post, by EliotX
Hello,
This game works, but anytime I get into a gunfight it crashes. I configured dosbox 0.73 to run as a 386 core. Turned off xms and ems - that didn't help.
Any thoughts?
I'm running XP Pro on a Dell Inspiron - thanks.
Reply 1 of 5, by EliotX
Anyone? The game plays okay (still crashes sometimes) when I only use a handgun,, but automatics crash it almost instantly.
Reply 2 of 5, by robertmo
This game should require cpytype=386_prefetch
So if you run it with cputype=386 maybe you are useing a game with prefetch patch. So maybe try to run the game without the patch.
Reply 3 of 5, by EliotX
Good suggestion, but I'm not using a patch (although there was one put out by a member of this forum).
I'm currently running 386_prefetch.
Whenever I run the game, it briefly mentions something like "maximum ems..." could that mean anything?
Also probably nothing, but when I installed the game from cd-rom (files were transferred there from original floppy) I got a "limited support" message due to the fact that I installed from a subdirectory. Again, probably nothing, but I suppose there's no harm mentioning it.
The game runs almost exactly the same (basically same crashes) on the patched version (using standard 386 in config) vs the non-patched ver. (using 386_prefetch).
Reply 4 of 5, by robertmo
"Maximum of 64K EMS used."
I think you could try to install the game from floppies just in case.
Reply 5 of 5, by robertmo
it is crushing with:
term.exe sblaster
it is not crushing with:
term.exe adlib
and
term.exe (pc speaker as default)
