First post, by retro games 100
- l33t
I'm sure you will agree that a 486 PCI motherboard made by the PC-Chips company must rank as one of the greatest manufacturing achievements of the 20th Century. And here's a photo of mine - I bet you're all jealous!
Joking aside, I bought a compact flash hard disk drive adapter from ebay. It's the kind where you plug a ribbon cable in to it, not the kind where you plug it directly on to the mobo's integrated IDE header. I plugged this CF device in to the middle connector of the ribbon cable, and then plugged the cable's end connector in to the CD-ROM drive. And it works! I just installed Descent 2 on to the CF device, from a CD-ROM.
Edit: I removed the "old and slow" 128mb compact flash drive with DOS on it, and replaced it with a 133x speed 2GB Transcend compact flash drive that had windows 98 on it, and it (slowly) booted up and worked fine.
