Openglide on MacOS X
First post, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
to move the discussion of the dosbox glide patch to the right discussion... 😀
When I start Dosbox, with the [glide]glide=true in the config, Dosbox crashes with
Glide:LFB access: read-write
Bus error
I guess I need to change the grport. But to what?
Just for the record, this is under OS X 10.6.1 😀 AND I've been using the CVS of Dosbox.
I'm attaching the error report, maybe this helps...
    dosboxerror.txt
    30.09 KiB
    669 downloads
Reply 3 of 69, by Dominus
DOSBox Moderator
Hmm, I just commented out the the whole thing in clock.cpp and then had to comment out ClockFreq = ClockFrequency( ); in glutil.cpp as well.
Now 3DFX Tomb Raider exits with the message "No PCI bus detected"
At least something, neither Dosbox nor Tomb Raider crashed 😀
console output:
CONFIG:Loading primary settings from config file /users/dominus/library/preferences/DOSBox 0.73 Preferences CONFIG:Loading addit […]
CONFIG:Loading additional settings from config file /users/dominus/documents/dosbox/tomb.conf
MIDI:Opened device:coremidi
Glide:GLIDE_PageHandler installed at 0x60000000 (384 pages)
One joystick reported, initializing with 4axis
Using joystick Adaptoid with 2 axes, 14 buttons and 0 hat(s)
Reply 4 of 69, by gulikoza
That means it is loading the original 3dfx glide2x.ovl not the dosbox modified one. Put the dosbox glide2x.ovl in the game directory. Make sure it matches the version of the patch (if you got the patch from this thread, take the ovl as well)
http://www.si-gamer.net/gulikoza
Reply 5 of 69, by Dominus
DOSBox Moderator
I have ONLY the glide2x.ovl from the first post of this thread on my system. I even copied the one from the debug folder in the zip and get the following log:
OpenGLide Log File
***** OpenGLide 0.09rc9 *****
Date: 21 Oct 2009
Time: 16:26:32
Clock Frequency: 0.00 Mhz
Configuration file is OpenGLid.ini
Time: 16:27:14
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 69, by Dominus
DOSBox Moderator
Oops my answer got lost...
Ok, I found the correct Tomb Raider patch (I didn't know there were two voodoo patches, I got the first one from the eidos pages).
Tomb Raider starts now, but after the videos, when it starts to render it crashes again with a bus error.
Console looks like this:
Glide:Activated
Bus error
Same happens with Lands of Lore 2.
Attached again the apple error log (don't wonder, I named the openglided dosbox, glidebox)
    glidebox.txt
    29.16 KiB
    622 downloads
Reply 8 of 69, by gulikoza
It seems to crash in openglide again. Perhaps you can activate the logging (uncomment #define OGL_ALL in GlOgl.h, recompile and then post the contents of Openglid.log). Maybe add some more logging in grSstWinOpen() to see exactly where it crashes. I'm afraid grSstWinOpen + 181 doesn't tell me too much 😀
Reply 9 of 69, by Dominus
DOSBox Moderator
grGlideInit( )
grSstQueryHardware( --- )
grSstSelect( 0 )
is what I get after that.
That's where my knowledge ends. I have no idea how to do that. Sorry...
Reply 10 of 69, by gulikoza
Just add a couple of those GlideMsg() calls. It behaves just like printf and the message should end in openglid.log. You can add messages like:
GlideMsg("Here");
GlideMsg("Still here");
and try to figure out where exactly it crashes 😁
Since there is no grSstWinOpen message, I assume it crashes before or somewhere in InitWindow().
Reply 13 of 69, by Dominus
DOSBox Moderator
Really except for doing simple tasks I'm lost in code.
I have no idea where in that code I should throw in some GlideMsg();
When I try I only make Dosbox crash with a "Glide:grSstWinOpen failed!" before the Bus Error, but not with an entry in Openglide. I'm really sorry for being that slow but I need some holding hands now 😀
Could you give me an example of where and how in grSstWinOpen() I should enter some glidemsg()?
Reply 14 of 69, by gulikoza
Ok, first let's try to copy the existing
GlideMsg( "grSstWinOpen( %d, %d, %d, %d, %d, %d, %d )\n",
hwnd, res, ref, cformat, org_loc, num_buffers, num_aux_buffers );
to the top of the function (line 249) so that we can see what parameters get passed. I still don't see where the code could crash with a null pointer dereference if the parameters are sane. So you could just add a simple
GlideMsg("1"); (increment the counter later)
after every line of code (just until before the original GlideMsg( "grSstWinOpen...") we know it doesn't come that far). The code after the last msg will be the problem 😀
If some moderator has some time, perhaps these last few posts could be split into a seperate topic Openglide on OS X in the Openglide development forum 😀
Reply 15 of 69, by Dominus
DOSBox Moderator
grSstSelect( 0 )
grSstWinOpen( 0, 7, 0, 0, 0, 2, 1 )
is the output in the log when I just copy the glidemsg from your post there.
I'll see about the other stuff either tonight or tomorrow, now I gotta go 😀
Reply 17 of 69, by Dominus
DOSBox Moderator
Thanks, HunterZ.
@gulikoza
OpenGL.WindowWidth  = Glide.WindowWidth;
OpenGL.WindowHeight = Glide.WindowHeight;
Glide.WindowTotalPixels = Glide.WindowWidth * Glide.WindowHeight;
OpenGL.WaitSignal = (int)( 1000 / OpenGL.Refresh );
After that it breaks. Anything I can do now?
Reply 18 of 69, by gulikoza
It crashes after these lines? Then it must be InitWindow. Perhaps you can add some msg lines in InitWindow()? Also just below the InitialiseOpenGLWindow() in Glide.cpp (line 79), you can add:
if(glGetString( GL_RENDERER ) == NULL) {
GlideMsg( "glGetString( GL_RENDERER ) returned NULL!");
return false;
if ( !strcmp( (char*)glGetString( GL_RENDERER ), "GDI Generic" ) )
ReportWarning("You are running in a Non-Accelerated OpenGL!!!\nThings can become really slow");
That strcmp might crash if it comes that far and OpenGL wasn't initialized properly.
Reply 19 of 69, by Dominus
DOSBox Moderator
Already did, nothing happens in there...
Hmm, doesn't seem to come that far, the log says the same:
grGlideInit( )
grSstSelect( 0 )
6789
(the last lines are the glide msg from grSstWinOpen())
Just for making sure, when compiling I get the following warnings:
grguDepth.cpp: In function ‘void grDepthBufferMode(GrDepthBufferMode_t)’:
grguDepth.cpp:85: warning: deprecated conversion from string constant to ‘char*’
grguDepth.cpp: In function ‘void grDepthMask(FxBool)’:
grguDepth.cpp:106: warning: deprecated conversion from string constant to ‘char*’
grguDepth.cpp: In function ‘void grDepthBufferFunction(GrCmpFnc_t)’:
grguDepth.cpp:131: warning: deprecated conversion from string constant to ‘char*’
grguDepth.cpp: In function ‘void grDepthBiasLevel(FxI16)’:
grguDepth.cpp:163: warning: deprecated conversion from string constant to ‘char*
grguMisc.cpp: In function ‘void grCullMode(GrCullMode_t)’:
grguMisc.cpp:78: warning: deprecated conversion from string constant to ‘char*’
grguSstGlide.cpp: In function ‘FxBool grSstWinOpen(FxU, GrScreenResolution_t, GrScreenRefresh_t, GrColorFormat_t, GrOriginLocation_t, int, int)’:
grguSstGlide.cpp:391: warning: deprecated conversion from string constant to ‘char*’
grguSstGlide.cpp: In function ‘void grSstOrigin(GrOriginLocation_t)’:
grguSstGlide.cpp:571: warning: deprecated conversion from string constant to ‘char*’
grguSstGlide.cpp: In function ‘void grSstIdle()’:
grguSstGlide.cpp:703: warning: deprecated conversion from string constant to ‘char*’
grguTex.cpp: In function ‘void grTexClampMode(GrChipID_t, GrTextureClampMode_t, GrTextureClampMode_t)’:
grguTex.cpp:207: warning: deprecated conversion from string constant to ‘char*’
grguTex.cpp: In function ‘void grTexFilterMode(GrChipID_t, GrTextureFilterMode_t, GrTextureFilterMode_t)’:
grguTex.cpp:280: warning: deprecated conversion from string constant to ‘char*’
grguTex.cpp: In function ‘void grTexMipMapMode(GrChipID_t, GrMipMapMode_t, FxBool)’:
grguTex.cpp:310: warning: deprecated conversion from string constant to ‘char*’
grguLfb.cpp: In function ‘FxBool grLfbReadRegion(GrBuffer_t, FxU32, FxU32, FxU32, FxU32, FxU32, void*)’:
grguLfb.cpp:237: warning: deprecated conversion from string constant to ‘char*’
grguLfb.cpp: In function ‘FxBool grLfbWriteRegion(GrBuffer_t, FxU32, FxU32, GrLfbSrcFmt_t, FxU32, FxU32, FxI32, void*)’:
grguLfb.cpp:297: warning: deprecated conversion from string constant to ‘char*’
GLRender.cpp: In function ‘void RenderUpdateArrays()’:
GLRender.cpp:129: warning: deprecated conversion from string constant to ‘char*’
GLRender.cpp: In function ‘void RenderDrawTriangles()’:
GLRender.cpp:330: warning: deprecated conversion from string constant to ‘char*’
GLRender.cpp: In function ‘void RenderAddTriangle(const GrVertex*, const GrVertex*, const GrVertex*, bool)’:
GLRender.cpp:712: warning: deprecated conversion from string constant to ‘char*’
GLRender.cpp: In function ‘void RenderAddLine(const GrVertex*, const GrVertex*, bool)’:
GLRender.cpp:1197: warning: deprecated conversion from string constant to ‘char*’
GLRender.cpp: In function ‘void RenderAddPoint(const GrVertex*, bool)’:
GLRender.cpp:1567: warning: deprecated conversion from string constant to ‘char*’
libtool: compile:  /usr/bin/g++-4.2 -DHAVE_CONFIG_H -I. -I/opt/local/include -I /usr/local/include/openglide/ -I/opt/local/include/SDL -D_GNU_SOURCE=1 -D_THREAD_SAFE -I/usr/include -arch i386 -mmmx -D__unix__ -D__linux__ -I./platform/linux -MT FormatConversion.lo -MD -MP -MF .deps/FormatConversion.Tpo -c FormatConversion.cpp  -fno-common -DPIC -o .libs/FormatConversion.o
/var/folders/zd/zd2LYc3pEZup1o0dxuhWVU+++TI/-Tmp-//ccOhPHaV.s:113:Alignment too large: 15. assumed.
/var/folders/zd/zd2LYc3pEZup1o0dxuhWVU+++TI/-Tmp-//ccOhPHaV.s:141:Alignment too large: 15. assumed.
/var/folders/zd/zd2LYc3pEZup1o0dxuhWVU+++TI/-Tmp-//ccOhPHaV.s:173:Alignment too large: 15. assumed.
/var/folders/zd/zd2LYc3pEZup1o0dxuhWVU+++TI/-Tmp-//ccOhPHaV.s:205:Alignment too large: 15. assumed.
/var/folders/zd/zd2LYc3pEZup1o0dxuhWVU+++TI/-Tmp-//ccOhPHaV.s:233:Alignment too large: 15. assumed.
grguBuffer.cpp: In function ‘void grBufferClear(GrColor_t, GrAlpha_t, FxU16)’:
grguBuffer.cpp:74: warning: deprecated conversion from string constant to ‘char*’
grguBuffer.cpp: In function ‘void grBufferSwap(int)’:
grguBuffer.cpp:112: warning: deprecated conversion from string constant to ‘char*’
grguBuffer.cpp: In function ‘void grRenderBuffer(GrBuffer_t)’:
grguBuffer.cpp:150: warning: deprecated conversion from string constant to ‘char*’
grguColorAlpha.cpp: In function ‘void grDitherMode(GrDitherMode_t)’:
grguColorAlpha.cpp:49: warning: deprecated conversion from string constant to ‘char*’
grguColorAlpha.cpp: In function ‘void grColorMask(FxBool, FxBool)’:
grguColorAlpha.cpp:109: warning: deprecated conversion from string constant to ‘char*’
grguColorAlpha.cpp: In function ‘void grAlphaTestReferenceValue(GrAlpha_t)’:
grguColorAlpha.cpp:296: warning: deprecated conversion from string constant to ‘char*’
grguColorAlpha.cpp: In function ‘void grAlphaTestFunction(GrCmpFnc_t)’:
grguColorAlpha.cpp:322: warning: deprecated conversion from string constant to ‘char*’
grguColorAlpha.cpp: In function ‘void grAlphaBlendFunction(GrAlphaBlendFnc_t, GrAlphaBlendFnc_t, GrAlphaBlendFnc_t, GrAlphaBlendFnc_t)’:
grguColorAlpha.cpp:424: warning: deprecated conversion from string constant to ‘char*’
grguColorAlpha.cpp: In function ‘void grGammaCorrectionValue(float)’:
grguColorAlpha.cpp:570: warning: deprecated conversion from string constant to ‘char*’
