Hi.
Anyone experienced with this device ?
I have just swapped my old Roland ED M-10 with this newer Edirol M-10MX because the right RCA out seems to have bad contact on the Roland.
The Edirol has solved all my noise problem and the sound is perfectly clear from all sources now.
It lacks balance LR control compared to the older Roland but has other advantages.
I would like to know two things:
- Input 5/6 has both RCA and 3,5 jack unlike the other ports. Could i use both at the same time to have one more source connected or could this damage something?
- there is a front hack input which doubles input 1/2 and it is marked as "plug in powered" and intended for a mic. Can i connect there something else than a microphone like the output of a computer without damaging anything?
It would make this one a 7 stereo sources mixer instead of 5 and would be better for my setup.
Thanks in advance.
