First post, by Majin Zero
Majin Zero
Offline
I was able to install it just fine, ran the patch, worked fine, I can start it up using: fall z.cfg
However, when I need to select things the keyboard shortcuts work fine, but I can not transfer the mouse control to dosbox like I was able to during the install, so I can not proceed with the character creation.
Any suggestions?
