First post, by cylis42
cylis42
Offline
Had been trying to instal The Dark Eye on 64-bit vista by mounting the image on Daemon tools with no luck. I had heard mount through dosbox might work. I mounted the cd in dosbox through the path set by the virtual cdrom in windows and when I try to launch the install app (DKYINSTL) it bumps down to a new command line that reads "win DKYINSTL.EX".
Not really sure what to do from there. Thanks for any help
