First post, by sehh
I'm trying to play Chaos Engine under dosbox v0.73 on Win Vista 32bit.
(btw, this is the very first game I've ever had a problem with this computer and dosbox version...)
The game starts, plays music fine and goes through some intro screen, but once it gets to the "LOADING" screen it just sits there and freezes.
I've tried different settings of cpu cycles from 1000 to 45000, cpu type normal and dynamic, etc.
So far none of it made any difference.
Any help please?
sehh
Reply 1 of 4, by eL_PuSHeR
It works perfectly fine for me, without doing anything fancy.
Run INSTALL.EXE and check audio settings et al.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 4, by sehh
I've run the install and audio settings are correct. When the game starts to play the intro I can hear the audio without problems.
sehh
Reply 3 of 4, by butterfly
Yeah, like, I mean... Make sure you chose hardware that is emulated in DOSBox. Try unplugging your joystick and select Keyboard and Joystick instead of Joystick and Keyboard. If the music plays maybe the issue is with sound or your software might of been damaged.
I'd also try no music, no sound effects to see how it goes
Reply 4 of 4, by sehh
thanks people, i'll try your suggestions and see what happens.
sehh
