First post, by Sabre Forrn
Sabre Forrn
Offline
I've been trying to get get Tie Fighter running in Dosbox but no luck yet. When I try to run the install executable I get to the menu but can't click on any of the install icons(they're blacked out), it tells me that I can't run the install program from the hard drive. The first time I did this I thought it was because I was using it from a folder I had put in the local C: of dosbox. The second time though I mounted my cdrom drive as d:\ -tcdrom and still had the same problem. Any help would be much appreciated, thank you in advance. I'm using the latest release .73 of Dosbox as well if that makes a difference?
