First post, by Arjen55
Hello peeps,
I have a little problem i guess. I have the connection between 2 lan pc's with Dosbox!
i use the commands:
PC 1= serial1 nullmodem rxdelay:50
PC 2= serial1 nullmodem server:IP PC1(192.168.xxx.xxx)
Well then i get the message:
Connected to 192.168.x.x
But when i start Jurassic war and choose Nullmodem, PC1 says connecting...
So i try to connect with PC2 but then i get this message "Connect fail-check com port"
Any solutions for this problem?
Reply 1 of 2, by jorian
Yes, see my topics you can read how to play it there. (though nobody knows yet how to play it with fast speed)
Reply 2 of 2, by paulmartin483
I was thought that It was require the server id for lan connection. You have to first read all the instruction about the game and after then connect both PC. It could be also happened when The game which you want to play wia lan connect. It was not supported in one pc. So checked it properly.
acekard
