First post, by Svenne
Yes, I finally got my hands on it. But I have a small problem: I cannot copy or move files. I'm running Windows for Workgroups 3.11, with 32-bit file access disabled, with Calmira LFN as shell with LFN's enabled, ontop of MS-DOS 7.10. The primary startup HDD is formatted as FAT-32, I think. I also created another HDD formatted as FAT-12/16, same result. Does anyone know what I'm doing wrong? I'll post the autoexec.bat, config.sys etc. as soon as I get home.
EDIT: Some settings files attached, hope they help.
Intel C2D 2.8 GHz @ 3.0 GHz | ASUS P5KPL | ASUS GTS250 1 GB | 4GB DDR2-800 | 500 GB SATA | Win 7 Pro/Ubuntu 9.10
