First post, by favor
I'm running DosBOX 0.72 under Unbuntu 9.04.
When I install Instant Recall 2.1 by Chronologic (an old DOS PIM), everything looks good and goes well. I check the install directory and all the necessary files seem to be there.
When I try to run Instant Recall I get "Install Error 108". There is also an error box put up by Instant Recall saying "Instant Recall error - please call (602)293-3100. Error: 621c-21-108". Of cource I can't call them since they have been out of business for many years.
I can install Instant Recall from the same CD into FreeDOS running under VirtualBOX and it runs fine.
Any ideas?
DoxBOX is great otherwise. I run an old DOS version of Quicken under it and it works fine!
Thank you all.
