First post, by Mangaboy
Hello,
I recently tried to play some Dos games like the Horde and 7th Guest on my computer. I have WinXp.
I tried many Dos emulators. I found them too complicated or not compatible enough. I am a Dos newbie.
I finally found one that's easier to configure: Shinod7.
I was looking for a way to play Tex:Murphy Pandora Directive on WinXP. I search on Google and found this French page:
http://www.shinod7.com/.
All the main files are on 3.5 disk. When you reboot your computer with the disk, the program is installed easily.
It works with plugins (sound, keyboard).
I tried 7th Guest and it installed like a charm.
I had some problems with sound but I downloaded a plugin for my AC97 chipset and it worked.
I removed the disk and rebooted to WinXp without a problem.
The main webpage is in French but there's an English forum.
Give it a try. It is updated constantly.
I found it a good alternative to Dosbox and VDMsound.
Tonight I will try to install Phantasmagoria 2 and Star Control 2.
For translation, you could use http://babelfish.altavista.com/
