First post, by Michigan
In The Settlers/Die Siedler (the very first part) the right mouse button doesn't work. So I'm not able to make a special click. In ordner to scroll the map/landscape, I have to hold down the ctrl key.
In Descent the right button works fine, but in Duke Nukem 3D it doesn't work, too.
I use DOSBox 0.73 with Dapplegrey frontend (2.7.1) an a cordless USB Logitech mouse under Mac OS X 10.6. I also tried DOSBox 0.72 and a cordless Speedlink mouse - with the same resoult. Does anybody has a solution?
