First post, by stefanoasr
Hi,
I have a "little" problem with a DOS game called "Allenatore - Italian Football Manager 2" (www.ifm2.com) :
As you can see in the screenshots (DOSBox 0.73), some text in the game is unreadable (this happens in older versions too). I also tried to edit DOSBox configuration (render and CPU), trying all the ways, but the result is the same.
Up to the old version 0.63, text looks good, but the mouse pointer is uncontrollable and the saved games index file is deleted each time the game gets started, so this is not possible to load previously saved games.
I hope there is a way to solve this problem...
Thanks to everybody in advance.
DOSBox 0.63
DOSBox 0.73
