First post, by panther8644
Hello i'm new to dos so forgive any mistake i may have made to cause this but while trying to install yobi's basic spelling tricks, when i run the setup it says the error in the subject line.... im running 64 bit of win 7. help?
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
uhm what do you don't understand from the error message ?
You are running a windows program in a DOS emulator
Water flows down the stream
Reply 2 of 2, by eL_PuSHeR
DOSBox as its name implies is for MS-DOS games, not Windows ones.
If your program is a Windows binary (executable), you just run it under Windows.
[THREAD CLOSED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
