First post, by keropi
Hiya!!!
In the grounds of testing my long wanted Disney Sound Source (thanks Salient!!!) I have tried to play Dangerous Dave II and III , and Keen Dreams... Sound source in Dave games is awesome (and you don't have to load the greedy sb's tsr for sfx too) but scrolling is way to jerky... As with Commander Keen Dreams... Also Realms of Chaos suffers
All of them run super smooth on my 486slc2/Cirus5424_ISA pc, but on my test K62/400+Voodoo3 scrolling is jerky.
I have tried my registered moslo with 386/486/p1 settings but games just crap out (another "wise" purchase of mine, it never actually helped me once in games... 🙄 ) ... I have tried the voodoo "vesafix" program but did nothing...
Any thoughts on the matter? Better written games play super smooth (jazz jackrabbit comes in mind, and turricanII) but is there a workaround for those Apogee classics?
Any help is highly appreciated as always 😊
Reply 1 of 13, by 5u3
Try the following things:
  • Slow down the K6-2 by hardware (lower FSB/multiplier, disable caches)
  • Install an ISA VGA card
BTW, VESAFix doesn't achieve anything, because those games don't care about VESA.
Reply 2 of 13, by keropi
yeah, I had the suspicion that vesafix was useless in this situation, but tested anyways 😀
Will try lowering speeds, but I am concerned that the voodoo3 behaves like some other vga chips that cannot produce smooth scrolling in these games (like tseng ones for example)
Reply 3 of 13, by aleksej
Hmm, very strange, i had same problem with ATI and Matrox cards only but never with voodoo 2d cards.
Reply 4 of 13, by keropi
with what configuration aleksej voodoo cards where OK? what cpu?
Reply 5 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Doesn't Keen have an SVGA compatibility fix option in its menu?
1+1=10
Reply 6 of 13, by keropi
it does not fix scrolling issues, AFAIK it fixes pallete/garbage-gfx ones...
Reply 7 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It fixes scrolling issues on some SVGA cards.
1+1=10
Reply 9 of 13, by aleksej
430HX + K6-III+ 500 (v3 & v5 pci)
MVP3 + K6-III+ 550 (v3 agp)
440BX + CUmine 1100 (v3 agp)
Reply 10 of 13, by keropi
really?! so fast cpu is not the problem... I wonder why they run jerky on my setup 🙁
Reply 11 of 13, by Harekiet
Rank DOSBox Author
DOSBox Author
It's just a prblem with some videocards not being 100% vga compatible in when they have to cache certain values that are used to render the next frame. That way certain values like pixel panning and start addresss aren't in sync and you get horizontal jittering. Not much you can do about it besides getting a different videocard.
Reply 12 of 13, by Calvero
Maybe the /COMP parameter fixes it.
