PowerVR Fun Thread
Reply 680 of 1104, by leileilol
Also in the shader I did attempt to try to mimic the feedback/bleed in your VGA captures 😜 though it may be too exaggerated...
The composite mode blur I don't think is captureable losslessly without needing some kind of dev box to dump the PVR2 buffer or so. I had to use old .TIF/.BMP press release screenshots as a reference for that.
I should still look into the bilinear filter which shouldn't be precise. On top of that, there's a bit for "supersampling" which seems to be a buzzword for more precise bilinear (more like geforce probably)
long live PCem
Reply 681 of 1104, by leileilol
I should probably post some shots of that current filter. A couple of these shots have a NTSC shader over them to demonstrate how this could be mistaken as 'anti-aliasing' on a TV.
It also should be noted that not every DC game enables the dithering!!! Soul Calibur turns it off, so being part of an internal shader for an emulator makes this better to control. Visual Concepts games like NBA2K etc allegedly don't dither either, but i don't have any of those. xjas's Armada VGA capture also shows a lack of dither, so that's something I've got to try (when Flycast's MMU/WinCE emulation works enough to start it)
    99.73 KiB
    73.35 KiB
    NTSC SVIDEO SHADER OVER THIS ONE
    100.09 KiB
    91.08 KiB
    71.1 KiB
    NTSC SVIDEO SHADER OVER THIS ONE TOO
long live PCem
Reply 682 of 1104, by Hanamichi
PureVex has been sold twice on yahoo auctions in the last 6 months..
Appears to be the same copy too, bought and resold..
So uhh yeah guess who bought it when it came up the second time 😀
Will test at the weekend and take some screenshots
Reply 684 of 1104, by Hanamichi
Thanks. PowerVR is the focus of my collection, underated imho but shame about the few and rare releases.
After over a year I gave up on the search for this, only to discover it recently by accident so you never know.
Reply 686 of 1104, by Hanamichi
About the price of a new game on steam 😉
I'm not sure what to do about it yet but I will definately need to preserve it, it's the only known copy worldwide as far as I can tell.
Taking some photos of my PowerVR stuff atm.
Reply 687 of 1104, by vetz
Hanamichi wrote on 2020-09-23, 21:15:
Sorry to give this info to you, but I know atleast about 3 other copies that exist, including the one I own.
Reply 688 of 1104, by Hanamichi
vetz wrote on 2020-09-23, 21:21:
Wow nice, that's okay it takes the responsibility away. Boxed or jewell case?
Anyway I really appreciate the API list and videos you did!
Reply 690 of 1104, by Myloch
Not considering YARRR dump should be more or less everywhere by now.
"Gamer & collector for passion, I firmly believe in the preservation and the diffusion of old/rare software, against all personal egoisms"
Reply 692 of 1104, by vetz
All patches/demo available for PowerVR games can be found in this thread: 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D)
Reply 694 of 1104, by dr.zeissler
What can I do if I have the mouse-pointer visable in the middle of the window in pvrgl games?
The mousepointer does not disapear, I don't know how to fix it. (Win95b DX5.2 4.1.2.c)
Reply 695 of 1104, by matze79
D0es your Graphics Driver allow disabling/enabling hardware cursor ?
As you wrote on dosreloaded you use ATI Card, which supports HW Cursor.
Maybe this is the problem ?
Reply 696 of 1104, by dr.zeissler
did not have that issue on win95b with dx61...but I think the problem is with ps/2 rate that I did not use on the previous installation.
perhaps I use another mousedriver like ms-mouse or logitech. (i do not use ps2/rate anymore but that did not solve it)
Reply 697 of 1104, by dr.zeissler
Hi there, I figured it out but stuck on another serious issue that I actually can't fix.
Changing from ATI-2560 to ATI-2440 does fix the mousepointer issue in PowerVR Quake1/Hexen2.
The PowerVR PCX1 destroys the sound on Games that use D3D via PowerVR.
It's not about the soundcard, it's drivers, regardless what soundcard or soundcard-driver I use, it stays all the same.
I tested different DirectX versions, but it's all the same.
e.g. JediKnight/JediKnight MOS, Hellbender. After a short time the sound is gone, stutters and then disappears.
If I choose the ATI for D3D it's also not working after I ran into the issue with the PCX1 before, so I have to do a restart
und then choose ATI for D3D and the sound is ok. Changing back D3D to PCX1 and the errors are back.
My conclusion is, that the PCX1 "writes" an error in the "PCI-Bus" that causes this issue when using the PCX1 for displaying for D3D.
I changed the PCX1 driver, but that does not solve this issue. I have to check if the PCX2 behaves the same.
Reply 698 of 1104, by dr.zeissler
I am giving up, I cannot fix this. the only way of getting rid of it is installing win98se installing all drivers and use dxdiag and disable direct-sound. then it seems to be ok, but this can't be the solution.
