First post, by thefix
I'm currently trying to capture footage from System Shock 1 and it seems like DOSBox has certain limitations when it comes to midi emulation, i. e. midi music isn't included in the captured footage. Looks like the only way to do it is triggering midi capturing seperately, converting the dumped mid file to digital audio and adding it to the movie in post.
The biggest problem with this is that I can't really press CTRL+ALT+F5 and CTRL+ALT+F9 at the same time so the video and midi data I've captured will never be truly in sync and in addition to the midi conversion, correcting this manually is a bit of a pain.
Is there a way to trigger video and midi capturing at the same time, e. g. using a script? My preferred setup is D-Fend reloaded with the current version of DOSBox, is it possible to pull something like this off with it? It looks like this question hasn't really been asked before but if it has, feel free to flame me into oblivion. Any advice would be much appreciated and thanks a lot in advance!
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
just bind them to the same key with the keymapper
Water flows down the stream
Reply 2 of 5, by thefix
Wow, it's that easy? I sorta expected doing this to cause problems of some sort but it's cool to hear that it doesn't, thanks a lot!
By the way, in order to convert the .mid to digital audio, the foobar plugin I'm using requires a sound font. Can someone recommend a sound font to me that sounds closest to DOSBox's own midi emulation? DOSBox itself doesn't really seem to be using a sound font as far as I can tell and for some reason, the sf2 file that comes with my ancient Sound Blaster Live! card doesn't really sound like the actual midi sound I get in DOSBox.
Reply 3 of 5, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Dosbox doesn't do any Midi emulation, MIDI is passed through to the host MIDI device.
Best thing to do is to use a audio capture program on the host (and maybe assign it the same hotkey for starting the capture as for starting the video capture in Dosbox).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 5, by Roxor
Alternatively, change the music device used by the game from General MIDI to something emulated by DOSBox, such as Adlib/Soundblaster or Gravis Ultrasound. Use either of those and the music will get captured along with the rest of the audio.
Reply 5 of 5, by robertmo
i wonder whether it would help to use gulikoza's build http://www.si-gamer.net/gulikoza/ with its mt32 switched to general midi with some sysex message.
