First post, by keropi
Hiya!!!
In the last days I am searching for a dos-only hex editor. The best I found so far is Norton DiskEdit , it has nice menus, mouse support etc... BUT it cannot cut bytes. Yep, no CUT. So getting a 10byte file down to 5 is not possible. (unless this feature is so well-hidden I cannot find it 🙄 )
So anyone can recommend me another hex editor?
Any help is greatly appreciated! 😁
Reply 1 of 7, by Vince.Bloodworks
Hiya 😁
I don't know a little piece of a cookie about working with HEX and I don't tried out this one but maybe ( I hope 😀 ) this one can help you.
http://www.pcwelt.de/downloads/tools_utilitie … pts_diskeditor/
Hope it's what you're looking for 😁
good luck and seeya 😀
Reply 2 of 7, by rfnagel
Dunno about a 'cut' feature, but this is the freeware DOS hex editor that I've used since 1994 (FileEdit binary file editor v1.65 - FED) -> http://www.simtel.net/product/view/id/41253 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
Reply 3 of 7, by keropi
thanks but that is not intended to edit files... 🙁
Reply 4 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
thought that there was a free version of hiew.
at least that is what I use to hex edit files under dos.
it can truncate files as well
Water flows down the stream
Reply 5 of 7, by keropi
@rfnagel: thanks , I will try it now
@Qbix: found this too, will give it a go
thanks!!!
Reply 6 of 7, by carangil
Cool, I'll have to try it too.
I always just used diskedit too... not having cut is annoying.
For small files I used debug a lot too, but after NOT doing anything like that for years, and now being spoiled by GUIs, I find debug completely insane to try to use.
Reply 7 of 7, by fatboy
I've always used XVI32:
http://www.chmaas.handshake.de/delphi/freewar … xvi32/xvi32.htm
I don't really know anything about hex, but I've had a lot of luck with this one. I've even used it to change a CPU ID check in "Virtual ON" which demanded that You have a CPU with the "Genuine Intel" ID. (I was trying to run the game on a P4, which does not have the Genuine Intel ID)
Open WIIIIIIIIIIIDE for chunky!!
