First post, by Vince.Bloodworks
Hello you guys
someone remembers Shadow Warrior ? 😁
I love the Build Engine games.... Blood most of them 😀
I installed Shadow Warrior on my system and all works correct, but I miss the music when playing it!
If I play with the original CD it works, with music. So I want to ask you whether you know a method how to play SW with music but without needing to use the original CD.
I even tried out to mount all the files from the CD from an iso file via IMGMOUNT D: D:\DOSBOX73\GAMES\SWARRIOR.ISO but it don't work.
Instead the game hangs up!
So please could you help me if it is possible to play it with music but without CD ?
Thank you guys 😁
Reply 2 of 7, by Vince.Bloodworks
Thank you for your reply. I saved the CD which is 145 Mbytes in CUE/BIN format which for surprise is 606 Mbytes. When I tried to mount this via imgmount DOSBox says something like: "can't read geometry from file" and
"use -size bps, spc, hpc, cyl parameters".
Am I right if I say this is because of the size of the file ?
And if yes, what should I tell to dosbox to mount it correctly ?
Thank you.
Reply 3 of 7, by robertmo
check IMGMOUNT in the readme
Reply 4 of 7, by leileilol
imgmount D C:\yourleetisofileshere\sw.cue -t cdrom
Should work. That 'size specify' stuff applies to hard drive images.
Reply 5 of 7, by Vince.Bloodworks
Thank you leileilol!
I've done the step you told me and it runs, but now I got soundinterferences
( music plays but very low and there are interferences like CHRRRRRR 😁)
Do you know how to solve this problem ?
Thanks
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
doesn't the game come with some sort of volume slider ?
Water flows down the stream
Reply 7 of 7, by Vince.Bloodworks
Inside the game you can set up the music volume ( which I've tested ), but it doesn't solve the problem 🙁
If I do so, then the music gets lower but the interferences is still the same with the same volume.
