First post, by Subversor
Hello!
I have Win 7 64 Bit...
I mounted my NFSSE iso to F:
I opened Dosbox 0.73 and I said
mount f f:\
mount c c:\nfsse
then in dosbox I opened f:\installd.exe (d for DOS! installw is not possible because it´s not an windoes executabtle)...
Then I can install NFS to C:\nfsse (it is clear that on my real pc that is c:\nfsse\nfsse because for my dosbox c is even c:\nfsse ...
After I have successfully installed this, i´m on the NFS SE home bildschirm where I can again click on "install". I can now even click on "deinstall" but I cannot click on "play". than I quit and it says: "you have succesfully installed NFSSE, to play just type in "nfs" (in dos!)
but even if i type in "nfs" in c:\nfsse there is nothing happening, only 2 lines appear "dos/4gw..." ... if i typ in f:\ and try to start the programm from the cd (there I tip in nfs_dos.exe) the 2 lines (dos4gw...) appear again and nothing more.
The iso is working I reached it for a few years...
In my opinion TNFSSE or dosbox can´t connect the drive with the cd drive, because... Maybe dosbox can´t find the cd or something... Must I mount the CD with a special command? (With power ISO I mounted my nfsse.iso to F:...)
Thank you very much beforehand!
