First post, by keropi
Hiya!!!
does such a program exists? Let me explain what I want to do... 😅
I am trying to make a batch file that will edit a variable in a text file , the variable depends on the location of the .bat file...
so for example if I have: c:\test\varedit.bat , it would open a file , look for a predefined string like %EDITME% and change it to C:\TEST\
I know I can get to a dos variable the current .bat file location with %~dp0 , but how to make %~dp0 replace the %EDITME% string in my file?
any pointers would be highly appreciated! 😁
Reply 1 of 11, by ratfink
That sounds like the kind of thing that would be fairly easy to write in BASIC.
Reply 2 of 11, by keropi
...if only I knew how to code... you don't know how much I regret it, maybe I start learning, basic for DOS or something simple like that...
Reply 3 of 11, by Davros
i wouldnt try replacing the string
i would have 2 files 1 with editme in and 1 with c:\test in it
lets say the file containing the string you want to be called result.bat
have 2 files called result.one + result.two
and rename whatever one of those to result.bat
so if you want to have result.bat contain c:\test rename one of the two files (the one containing c:\test) to result.bat
edit: I think ive misundestood what your trying to do
you want to :
if file exist then replace string ? yes ?
IF exist Command:
IF EXIST c:\test\varedit.bat COPY c:\test\result.one c:\test\result.bat
Reply 4 of 11, by keropi
What I am trying to do is this:
have a file called: keropi.cfg that it has for example:
# keropi config #
keropi path=%EDITME%
blah
blah
so I have a set from before an environment variable like: SET keropipath=C:\KEROPI
and the program would grab C:\KEROPI and write it in where %EDITME% is...
ps. I think I won't find what I need unless I can code it myslef 🤣
Reply 6 of 11, by (stolen.alias)
this can easily be done with a batch file, for the example you gave...
create a file c:\header.txt containing:
# keropi config #
create a file c:\footer.txt containing:
blah
blah
create a file makecfg.bat containing:
@type c:\header.txt > %1
@echo keropi_path=%EDITME% >> %1
@type c:\footer.txt >> %1
now run makecfg with parameter of the filename you want to create..
ie.. makecfg keropi.cfg
if you would rather supply the %EDITME% text on commandline you could have a makecfg.bat as:
@echo keropi_path=%2 >> %1
then run as
makecfg keropi.cfg c:\my\path
to create the file...
Reply 7 of 11, by keropi
yeah, I am pretty sure the above batch file(s) will only work under windows XP/vista/7 command prompt and not under pure old plain DOs...
Reply 8 of 11, by (stolen.alias)
nope... will work fine under plain dos...
for example here's an old batchfile(testzips.bat) i just snagged from my old 286 running dos 3.3 that ran a node of my bbs in the early 90's, the batchfile creates and runs a second batch file (testem.bat) that runs a third batchfile (add2zip.bat) on each .zip file within the directory that was specified as a parameter to the first batchfile (was used to test .zip uploads)..
@echo off
rem run as: "testzips drive:\some\path"
rem %1 directory containing files to test
echo testing uploads (.zip ) ...
rem delete old logfile...
if exist testfile.log then del testfile.log
echo Testing files (.zip). Please wait...
rem create batch file to test each .zip file...
if exist testem.bat del testem.bat
for %%f in (%1\*.ZIP) do echo call ADD2ZIP %%f %2 %3 >>testem.bat
rem call the created batchfile
call testem.bat
rem log any failures
if exist testfile.log echo one or more files failed -- consult FAILED.LOG...
type testfile.log >> failed.log
Reply 9 of 11, by keropi
really? then I will test asap , I have tested many solutions lately, only to find they where windows command prompt specific ...
thanks! 😀
Reply 10 of 11, by elianda
I'd just want to mention that the classic edlin editor that comes with dos is fully remote controllable by piping in the commands.
And its damn fast aswell.
Youtube Channel
Reply 11 of 11, by Varka
edlin
Great. Back to therapy I go.
