Trying to cover all ground.
First post, by Thirst
I've spent some time now trying to cover as much compability I can gamingwise, but there's still a few potholes here and there.
I would love any suggestions on what to improve.
One thing I noted is that the recommended specs for Wing Commander 3 (and possibly other titles of the time) recommend a Pentium for a decent SVGA experience. Not sure if I need to redeem this with a seperate machine or not.
DOS / Windows 3.1 machine - 1994
486DX4 @ 100Mhz 256KB L2-cache
PAT48AG Motherboard
16MB FPM RAM
Cirrus Logic 1MB VLB
Promise DC2300 VLB controller card
Creative SB16 CT2940
200W AT PSU
Sony 8x CD-rom
Spare parts
i586
i486DX2-66
i486DX-33
SB-16 CT4180
Changes
VLB controller card unstable/broken. Wont boot.
Glide Windows 98 machine - 1998
AMD K6-2 @ 550 Mhz
V72MA Motherboard
NCP 265MB PC-100
2 x Mismatched Voodoo2 12MB running in SLI
Soundblaster Live!
IBM Aptiva case 70W PSU
Spare parts
AMD K6-2 @ 400Mhz
Creative Geforce2 GTS 32MB
Changes
By far the weakest unit. Only 3 PCI slots. Only supports up to 256MB of RAM. Wont run Outcast very well at max settings. Look into replacement.
Singlecore Windows XP machine - 2004/2005
AMD FX-55 @ 2.6 Ghz
Gigabyte GA-K8N Pro-SLI Integrated sound
Thermaltake Golden Orb II Cooler
Geil 1024MB DDR400 PC3200 CL=2.5-8-4-4
Kingston 1024MB DDR400
Radeon X800 XT
Antec case 500W PSU
Spare parts
Gigabyte Geforce 7800GT
AMD Athlon 64 3700+
Changes
Switch out the radeon for a later GPU?
Introduce a audigy2 sz soundcard
Dualcore Windows XP machine - 2007
Intel Core2Duo E6750 @ 2.66Ghz / 1333Mhz 4MB
Asus P5N32-E SLI Plus Gblan Socket 775, Integrated sound
Thermalright Ultra-120 Cooler
Noctua 120mm Fan (NF-S12-1200)
Corsair Dominator 2048MB DDR2 XMS2-8500 @ 1066 Mhz (5-5-5-15)
2 x Geforce 8800GT running in SLI
Antec Performance One P190 (1200W 2x PSU)
Changes
Add another 2gb of RAM?
Reply 1 of 27, by ratfink
Similar to what I have ended up with, ie. 4 machines, though differing in detail.
I used k6/x's for my glide/98 box for a long time but it was always too slow for later glide games. Now I use an xp2000+ which seems able to cover an awful lot of ground [especially if I swap the voodoo5 for a ti4], and the 95 box covers earlier stuff when I want to play it on vintage hardware.
Are there some games that play on the fx-55 system but not on the core2duo?
Reply 3 of 27, by Thirst
I'm considering replacing the k6-2 with an athlon t-bird at 700mhz or so for late -99, early -00 gaming but I'm worried about breaking compability with ca -96, -97 titles.
About the FX-55; yeah, quite a few early win xp games wont play nice with a dualcore machine. "Beyond good and evil" and "Psychonauts" come to mind.
Reply 4 of 27, by retro games 100
Thirst wrote:
... quite a few early win xp games wont play nice with a dualcore machine. "Beyond good and evil" and "Psychonauts" come to mind.
Can this be solved by setting the CPU affinity to one core?
Reply 5 of 27, by Qbix
Rank DOSBox Author
DOSBox Author
I think GOG.com sells those, so I doubt that they wouldn't run on dual core machines somehow
Water flows down the stream
Reply 6 of 27, by retro games 100
I just installed BG&E (from a retail DVD-ROM) on to a C2D system. It seems to work OK. There's an advanced settings tab where you can adjust things if you experience problems with the game. (I didn't have to adjust anything.)
When you say games such as BG&E wont play nice with a dualcore machine, can you describe what the problem(s) are? Thanks.
Reply 7 of 27, by Thirst
It's been a while since I attempted it so memory is a little vague on the details of the rig I used but the issues I had with BG&E was primarily with sound going out of synch during cutscenes and the water behaving very eratically when on the hovercraft.
In Psychonauts the sound would stutter every 10 seconds or so. This was on my most current setup, and setting CPU affinity to one core would not alleviate the problem, though I admit I didn't search for very long for a patch to fix the issue.
The fact that GOG.com sells the games would suggest there are ways to get around the problems but these are usually game specific, and it's just easier for me to have a computer that's already compatible sitting under the desk, than to hunt down individual workarounds for every game.
Both games being console conversions, it makes you wonder if it's not just a case of lazy coding.
EDIT:
San Andreas, SW: Battlefront and Deus EX: IW also have some timing issues on C2D systems but these can iirc, be fixed by changing the core affinity.
My reasoning for the singlecore machine is to simply have a hassle-/glitchfree install and play enviroment for these games.
Reply 8 of 27, by Old Thrashbarg
With regards to your Win98 machine:
Try bumping it down to 128MB RAM and see what happens. From what little I can find about that board, it looks to have the ALi Aladdin V chipset, and if it's one of the earlier revisions, it'll only cache up to 128MB RAM when equipped with 512K L2. That could explain lackluster performance in games.
Reply 9 of 27, by Thirst
I gave 128MB a whirl. I'm not sure if it's just my imagination or if it's actually running slightly faster. Still only getting 5-10 fps in Outcast sadly. Good idea though 😀 ty
I think I'm going to have to throw this one out for a thunderbird instead. I just hope it wont break any early Win95/98 games.
Reply 10 of 27, by Old Thrashbarg
I'd say that it wasn't an issue of cacheable RAM, then. Usually when there's an issue like that, the difference in performance is large enough to leave no doubts. It was worth a shot, though.
I really don't think you're going to run into any compatibility issues by going to a 700mhz Athlon. At least, no more than you would with that 550mhz K6-2. There are several people on here using upper-end PIIIs without troubles. And you could always keep that Socket7 board around in the spare parts bin, just in case you do chance upon a game that doesn't work well.
Reply 11 of 27, by Thirst
Sounds good 😀
Another question regarding the Win98 machine; is SBLive! as good as it gets for gaming or are there alternatives I should be looking at?
I've looked around a bit online and here on the forums, and it seems that while other manufacturers have richer feature sets, the soundblaster way seems the more compatible one. I wouldn't mind switching out cards for individual games but technical sound terminology is bewildering, and I'm not sure what to look for.
The Roland Lapc-i has been heralded a lot but seems hard to get a hold of and I'm not sure it's suitable for the more modern system.
Reply 12 of 27, by retro games 100
Outcast is a game known to have strange speed related compatibility issues. For example, if you run it on a fast P3, then your character's movement through any of the water sections goes in to a kind of "slow motion" mode. The game becomes unplayable. I wonder if something odd is going on, with the K6 CPU. I know if I run the game Might and Magic 6 using a T-Bird, the game's mechanics go wrong. For example, the NPCs get stuck walking on the spot. If I remove the T-Bird, and replace it with a slow Duron, this problem goes away. Also, if I run this game on any P3 CPU, this problem does not occur.
Reply 13 of 27, by Thirst
It might be an issue with the K6 specifically yeah. I wish I had a P3 of similar speed to try it on.
What was the speed difference between the duron and the t-bird that gave you trouble?
Reply 14 of 27, by retro games 100
I'm fairly sure the T-Bird CPU was 1000mhz, and the Duron CPU was 750mhz. I seem to remember trying both a B and C model T-Bird - in other words, a 100FSB and also a 133FSB version. Both T-Birds made the M&M6 game behave oddly.
Reply 16 of 27, by retro games 100
Thirst wrote:
I'll have a look for a PIII @ ca 800Mhz. It should push through Outcast at max settings without breaking compability with earlier games such as M&M6.
I'm confident that a PIII @ 800mhz will be a very good choice for both Outcast, M&M6, and a whole ton of other old Win9x games. I have used one of these CPUs for lots of testing, and found them to be a good solid performer.
Reply 17 of 27, by valnar
I went on a retro PC building craze, then promptly a retro PC selling craze a couple years later. It turns out I enjoyed building them more than playing them.
I'm down to two PC's now. My Win98 box with a PIII 1.0Ghz running Win98 and my current rig with an E8400 C2D. DOSBox takes care of most things older than what runs on Win98.
Now mind you....both of those are decked out and I have more MIDI devices than you can shake a stick at. 😀
Reply 18 of 27, by Thirst
The P3 did wonders for Outcast. 😁
My 486 still wont behave though. With the Promise controller card in, all I get is a black screen, and without it I'm stuck without a HDD.
I was eyeing a card on ebay ( http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewIt … e=STRK:MEWAX:IT) but that one was for the ISA bus only, unlike mine which supports VLB. Will I experience a dramatic performance hit with the inferior card?
Reply 19 of 27, by Old Thrashbarg
That card you linked is not even an IDE controller, it's MFM. Those things were obsolete several years before 486s even hit the market. Putting aside the considerable difficulty of finding a working MFM drive, "dramatic" wouldn't even begin to describe the performance hit... that thing would make the machine unusably slow.
A later model 16-bit ISA EIDE controller would be able to deliver passable performance, at least in comparison to your older VLB card. Yeah, there'd be a little bit of a penalty, but it wouldn't necessarily be that big of a difference as long as you got a decent card.
How much troubleshooting have you done with your existing controller, though? There's any number of things that could cause it not to work, which may or may not be any fault of the card itself.
