First post, by gm_matthew
I can't help but feel that the way the screen size changes in Pinball Fantasies and Illusions is weird, particularly with Pinball Illusions. The screen resolution changes to an irregular size at each of these moments:
1. Main menu of Fantasies, when the sidebar slides in.
2. Several times during Illusions intro.
3. Illusions main menu, looks fine at first but turns out that borders are trimmed.
4. High resolution modes in Illusions, trimming the sides (yes, they work okay if you set the machine type to svga_et3000, but the sides are still trimmed).
It seems that the two games tend to cut any black sections from the screen whenever they do this. It is most annoying with the sidebar in Fantasies and the Illusions intro, since in full-screen mode the image is not positioned correctly.
Is it DOSBox that is doing this, or is it the games doing weird stuff with the VGA/SVGA? And can it be fixed somehow?
