Clive Barker's Undying Texture Errors
First post, by Cliche
Greetings everyone. So, lately I was playing using dgVoodoo and found these:
I've tried zeckensack's, psVoodoo, & OpenGlide but the results are the same. I wonder if anyone have a clue about this issue.
Reply 1 of 23, by lightmaster
tried nhancer?
Reply 2 of 23, by Cliche
Would that mean changing to the D3D renderer?
Reply 3 of 23, by lightmaster
dunno, i'm no expert with that proggy.
Reply 5 of 23, by Davros
why in the hell are you playing undying with a wrapper ?
Reply 6 of 23, by Cliche
Well I thought all Unreal 1 engine games were meant to be played using Glide (judging from KHG, WoT, NerfArena). But that doesn't seem to be the case.
Reply 7 of 23, by DosFreak
IIIRC, not all Unreal engine game renders are the same.
Only way to be sure it's not a wrapper issue is to try it with a real Voodoo card.
If there are still issues then it's highly likely the game devs never really tested the game with a Voodo card.
Make your games work offline
Reply 8 of 23, by Cliche
Hey Davros, does the fog in your game look like this? (This one using the D3D renderer)
Reply 9 of 23, by keropi
I have a working v5500 setup with my copy of Undying, post some saves in the problematic areas so I can post back shots
Reply 10 of 23, by Cliche
Here, one just outside the mausoleum and another one for checking out the kitchen's basement.
Reply 11 of 23, by keropi
...and what is the screenshot button? :p gonna try them NOW
edit: your saves do not work, I put them in /save/ folder and after running the game they get deleted.... I think you need to post your whole save folder...
Reply 12 of 23, by Cliche
You can just double-click the .sav file (hope it's not associated with any program) and choose select program from a list and find undying.exe.
Screenshot default is F5, IIRC.
Reply 13 of 23, by keropi
OK, droping the saves to undying.exe worked fine 😀 (F9 is the take screenshot button btw)
all look OK, those shots are from Glide renderer, voodoo5500/AGP with amigamerlin2.9 drivers and win98SE (game patch applied also)
damn, now I need to replay this classic 😊
Reply 14 of 23, by Cliche
Nice shots keropi. I assume the mirrors in your game work fine too. Well I guess these errors I get are caused by my vga driver then. My guess is it has something to do with texture blending/transparency or some sort. Would be nice if someone else could post some screenshots using dgVoodoo.
Reply 15 of 23, by Davros
have you tried zackesacks wrapper if your determined to run in glide
ps: in d3d your not running in 16bit are you ?
Reply 16 of 23, by Cliche
Yes I've tried most glide wrappers. I've also tried both 16bit and 32bit D3D and the fog looked the same. VolumetricLighting in most of my Unreal 1 games looked so ugly using the D3D renderer, that's one reason I'm using Glide.
Reply 17 of 23, by Davros
what gfx card do you have ?
Reply 18 of 23, by filipetolhuizen
I assume it's a newer Geforce card right? because lots of D3D functions are missing in the drivers. I think it's ridiculous that nvidia hasn't fixed this in 3 years.
Reply 19 of 23, by Davros
Well I run a modern geforce (gtx260) and have no problems as far as I can tell
