Instructions
Everyone already got mad when you see things like this:
- Code: Select all
C:\DOCUME~1\ASMDEV>
Instead of this:
- Code: Select all
C:\DOCUMENTS\ASMDEV>
But now you can have long file names working on Windows 3.11
Requirements
Now we need to download the file ifa400.exe, called Long File Names for Windows 3.1x Programs.
Installation
Copy the file ifa400.exe to where you want(on this tutorial I will put it on C:/), then you need to open the Windows 3.11 File Manager and double-click on the executable:
Just do as every good Windows setup(Next, Next..., Finish
Registration
Instant File Access version 4.00 FREEWARE. Registration info is:
- Code: Select all
Address: Free Registration
Registration Number: 2782913346
This isn't warez, as I've said, it's the FREEWARE serial!
Now just restart Windows and you will have long file names working and all your problems are solved now:
