First post, by TOAD
The title pretty much says it all..
I have no idea how to use the keymapper to setup my Dual Action LogiTech controller.
Could anyone help me out ?
Reply 1 of 7, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
what games have problems?
post content of "DOSBox Status Window"
enclose your dosbox's config file
Reply 2 of 7, by TOAD
DosBox version is v0.72
I don't remember where I downloaded it from
PC specs:
eMachines T5088
Windows Vista Business 32bit
No games have problems, yet, because I haven't even figureed out how to use the keymapper to configure the LogiTech Dual Action Controller. However, I'm trying to play Mortal Kombat 1 and 2. Arkanoid seems to work though, without having to manually configure anything.
The Config file is attached...
Reply 3 of 7, by robertmo
0.72 is OOOLD
get the latest one from official page www.dosbox.com and remove old mapper file.
Reply 4 of 7, by TOAD
Thanks ... Will give that a try
Reply 5 of 7, by TOAD
OK
I'm using version .73 now
Same story. I can run Mortal Kombat fine without problems. I just don't know how to use the keymapper to configure my controller. How do you use the keymapper ?
Reply 6 of 7, by robertmo
check dosbox's manual
but basic buttons and axis should work without using the mapper if the game supports joystick (in mk press f10)
Reply 7 of 7, by xeno killer
You should just use Xpadder 5.3
It emulates your keyboard to a controller and gives you full control over it.
Much easier than the configuring DOSbox and the program itself doesn't require installation.
