First post, by Daqar
Heya,
I managed to install Mechwarrior 2 under dosbox 0.73 without problems. When I ran the game the first time, there was white noise for music and I turned off the music.
When I run it now, there is neither sound nor music.
On top of that I have some keyboard trouble. [SPACE] is supposed to fire the selected weapon, and then cycle to the next. [ENTER]/[RETURN] is supposed to cycle through the weapons. However both [SPACE] and [ENTER/RETURN] fires the selected weapon and cycles to the next.
I'm using dosbox 0.73 under OpenSUSE 11.2 64 bit and I believe its Mechwarrior 2 ver. 1.1
Best regards,
Daqar
Reply 2 of 13, by robertmo
for space/enter remove mapper.txt
Reply 3 of 13, by Daqar
DosFreak wrote:
Verify that SFX is configured correctly in the game setup.
As for Music it won't work unless you are using a CUE/BIN image of the game mounted via imgmount.
Ok, so I might have to re-install the game. The soundcard setup that I need to use is the one that dosbox displays when starting up, right?
I'm already using CUE/BIN image of the cd. But I'm not sure which one to mount. Does that matter?
I'll try and find and delete that 'mapper.txt' file...Is it a dosbox file or mechwarrior 2 file?
Daqar
Reply 4 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
yes,
cue file, yet it matters
a dosbox file
Water flows down the stream
Reply 6 of 13, by Daqar
Qbix wrote:
yes,
a dosbox file
I'm already mounting the cue file. That leaves a re-install of the game, and I need to remove mapper.exe.
I can't find mapper.exe, I made a search for it on my system. I'm quite new to linux, so I don't know if I managed to do a search on the entire system. I know for a fact that the file is NOT in /home/jacob/.dosbox/
Daqar
Reply 7 of 13, by Daqar
I can't find the edit button, so I'll have to post a new reply:
I just tried reinstalling, making sure I was using a soundblaster card and the address 220. Still no sound. This problem also occurs in Doom2 and Heretic, so I'm not sure its a game-specific problem anymore...
Daqar
Reply 8 of 13, by leileilol
It might be an actual mixer problem, sounds like your real sound device is trying to force 8-bit output on a 16-bit stream or the versa (doubt the versa).
Reply 9 of 13, by robertmo
you also need to use irq and dma
Reply 10 of 13, by Daqar
Even though I tried to set up the soundcard manually I wasn't allowed to set irq or dma...I dunno why. After setting the address 220, the installer just said the device was detected successfully. Actually it also claims that when autodetecting the soundcard.
I still can't find mapper.exe what folder should it be in?
Daqar
Reply 11 of 13, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
what games have problems?
post your exact mountings
post what is written after you mounted
post content of "DOSBox Status Window"
enclose your dosbox's config file
Reply 12 of 13, by RaVeN-05
Use GZDoom for Doom2 and Heretic, its best choice.
Reply 13 of 13, by lightmaster
Or try 0.74 ((:
