First post, by Love the classics
Been running 0.72 for years on an XP machine, worked great. Just built a new system running Win 7, 64 bit. Did some research and found I'd need 0.73 for Win 7. Downloaded it, setup my config, mounted C:, CD Drive etc, launched one of several old DOS games I had and everything looked fine except.... and this goes for everyone of the 14 programs I have in my CDrive directory; about 1-2 minutes after launch of any of these programs, the video corrupts(?) and looks to drop into a 16 color?, EGA? mode?
I've used every video emulation available in the config file to no avail. Hoping someone has some ideas.
System:
Intel I7 processor @ 2.66
Gigabyte MB GA-X58A-UD3R
Ram 6 gig Corsair
Video Sapphire 4870 1 gig VRAM
BTW I have the newest drivers loaded for everything. Sytem was just built about a month ago.
Many thanks to any respondants.
Reply 1 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
kill explorer.exe 😉
anyway wait for 0.74
win7 their explorer corrupts the palete
Water flows down the stream
Reply 2 of 10, by robertmo
try different output=
Reply 3 of 10, by Love the classics
kill explorer.exe
So how would I do that? Is there even a way? And is a 0.74 under development?
Reply 4 of 10, by Love the classics
I've tried that... started with surface, currently ddraw, tried opengl etc. nothing worked. Apparently explorer corrupts the pallete.
Anyone running in Win 7 64bit with success?
Reply 5 of 10, by DosFreak
Final option is to set the SDL_VIDEODRIVER=WINDIB variable.
Either that in your System Variables or create a batch file as follows:
set sdl_videodriver=windib
dosbox.exe
Make your games work offline
Reply 6 of 10, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Is the pope catholic?
Seriously, Dosbox is always under heavy development and yes, a 0.74 is under development and doesn'T seem like toooooo far off 😀
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 7 of 10, by Love the classics
Well, tried setting the SDL_VIDEODRIVER=WINDIB variable.. no luck.
Guess my only option is to wait for 0.74 😒
At least I can still play around on my old XP machine 😉
Thanks for all the responses guys.
Regards,
Gary
Reply 8 of 10, by lightmaster
last resort, try a svn build.
Reply 9 of 10, by leileilol
Change output= in the .conf file, not during the run of the emulator. Opengl shouldn't ever use a screen palette or 8-bit color (which Windows 7 will definitely screw).
No, I don't have Windows 7, I don't even know why i'm posting! The good samaritan in me wants me to!
long live PCem
Debian's fucked
Reply 10 of 10, by robertmo
type
output
inside dosbox and tell us what it replies
