First post, by dnd
is there a known problem with certain screen modes (?). i get clipping problems with vehicles and sometimes ppl clipping through the background scenery in syndicate. it only seems to happen on the levels that use the 'green' colour palette.
Reply 1 of 7, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
post content of "DOSBox Status Window"
enclose your dosbox's config file
Reply 2 of 7, by dnd
dosbox 0.73 from dosbox hompage
windows 7 pro x64
core 2 duo 2.4g, 6 GB RAM, 8800gtx
DOSBox version 0.73
Copyright 2002-2009 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file C:\Games\Synd\dosboxSynd.conf
MIDI:Opened device:win32
SHELL:Redirect output to nul
    dosboxSynd.conf
    6.76 KiB
    98 downloads
Reply 4 of 7, by dnd
ah...no, it was one of the things i was fiddling with to see if it fixed it. i've tried svga_s3, vgaonly, svga_paradise as well. also tried ddraw/overlay/opengl/openglnb and various scalers, though not specifically to fix this issue.
