First post, by MadMonk
Has anyone noticed the sound difference between v. 70 and v. 73?
Sounds in 0. 73
This change appears only in few games, such as in Bio Menace the shooting- and key pick-up sounds are quite different.
Game music in 0. 73
The quality change is small but noticeable. Some games, especially ROTT, Major Stryker, Duke Nukem II, Monster Bash and other games which use AdLib music have expectional music quality compared to v. 70's.
IMO v. 70 supports the best music- and sound quality. So, I want to have the v. 70's sound and music quality to v. 73. The reason why I'm using v. 73 is cause I'm recording some of my playthrougs (v. 70's video capture doesn't work)
All in all, how can I get the v. 70's good sound and music quality to v. 73? Should I edit the conf.? And could I get a copy of unedited v. 70's conf. -file somewhere?
Reply 1 of 13, by wd
Rank DOSBox Author
DOSBox Author
What are your rate= settings in the config files?
Reply 2 of 13, by MadMonk
rate=22050 (v. 73)
I've lost my v. 70's conf. during the update.
Reply 4 of 13, by MadMonk
I'm not sure I understand your post. You can try playing with "oplmode" "oplemu" and rate options in dosbox.conf
Seems like it works. Could you still tell me v. 70's oplrate? I can't check that out cause v. 70's conf. switched automatically to v. 73's
Reply 5 of 13, by robertmo
rates were the same in 0.70
install both dosbox's. you can even install some more versions. every dosbox has his own dosbox-ver.conf (you see in status window where its location is)
Reply 6 of 13, by wd
Rank DOSBox Author
DOSBox Author
If you want good adlib support use 0.73 and check the comment at oplrate.
Reply 7 of 13, by MadMonk
DOSBox 0.73 has been released! […]
Most noticeable changes:
•Support for more graphics modes and cards.
•Improved Vista support.
•New OPL emulation cores.
•Sound fixes and improvements for Mac OS X.
•Lots of compatibility fixes.
•Lots of cdrom detection improvements.
•Lots of memory (EMS/XMS) improvements.
•Various fixes and enhancements for the recompiling core.
•Support for evdev.
•Lots of DOS fixes.
•Slightly faster!
•More stable.
I think, that changed the music quality.
Reply 8 of 13, by Qbix
Rank DOSBox Author
DOSBox Author
Water flows down the stream
Reply 9 of 13, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
... towards the real thing. You are just used to the old wrong one.
1+1=10
Reply 10 of 13, by Hater Depot
If you haven't played the games on a real DOS system with an Adlib then you don't really know wheher 0.70 or 0.73 is more accurate.
Korea Beat -- my cool translation blog.
Reply 11 of 13, by Teppic
While on a topic of oplrate, when I use 49716 on both the mixer and oplrate I get really muffled music. If I change the mixer to 48000 it sounds fine.
Is this a bug, or can't my Sound Blaster Audigy 2 play back this correctly?
Reply 12 of 13, by wd
Rank DOSBox Author
DOSBox Author
Right, means resampling of your soundcard to this rate is borked.
Use 48000 or 44100 (assuming those sound better) for all rates then.
