First post, by snipe
Hi all, Just wondered if someone could help me out here.
I have successfully managed to get windows 95 running via DOSBox, I have DOSBox portable running on my USBdrive and a hdd image which contains a windows 95 installation, also in that directory. So I now have a portable windows 95 system which I can run on any machine be it mac or PC. So far so good!
I then managed to get the correct sound drivers installed so that the emulated SB16 card works nicely and I was able to hear the old familiar windows start-up tune! I managed to install the correct display drivers so that I have 1024x768 resolution and 16bit colour.
OK then, my problem is getting the internet up and running, ie communicating with the router used by my host machine, via the emulated dial-up modem in DOSBox.
For instance I need a telephone number to dial out to, is this the IP of my router, or the host PC?
Any advise would be very welcome.
Many thanks.
