First post, by RanCorX2
does anyone know how to get this game working on win7 x64? The installer doesn't work because it's 16bit? and i tried copying the contents of the cd to a folder and running it that way but just get a black screen with music.
Reply 1 of 16, by DosFreak
I have the demo and I've only ever gotten it to work on Windows 98SE.
Supposedly it supports Glide so you may want to try the following Glide Wrappers:
DGVoodoo
ZeckenSack
Nglide
OpenGlide
Make your games work offline
Reply 2 of 16, by RanCorX2
I suppose getting it to work on dosbox + win98 is out of the question? since none of the emulated machines can emulate decent video cards right?
Reply 4 of 16, by RanCorX2
I just had a go at that, followed all the instructions but it still doesn't work 🙁 It loads, black screen and minimizes to the tray and just sits there.
Reply 5 of 16, by Wulf
I've found a LOT of my games do that, close that instance (right click on it minimised), then set Compatibility mode to disable desktop themes & colours (can't remember exactly what the settings are called, they're together on the list). It should work thereafter. Mine does.
Reply 6 of 16, by RanCorX2
ok, I managed to get past the title screen but then I get a black screen instead of the menu, the music is playing though. I tried 95, 98 & xp modes and disabled themes, aero etc but nothing makes it load past the intro.
Reply 7 of 16, by Wulf
hmm... OK, I know you said you did, but are you SURE you followed the instructions COMPLETELY? Applied the patch, made a new CD, installed from that, etc?
Like I said, it worked for me...
Reply 8 of 16, by RanCorX2
I've given in, gonna install xp on a usb stick.
Reply 9 of 16, by Wulf
Mine works technically (ie, there's no problem with the program), but in the game my x-wing keeps disappearing into the distance! I don't remember that being part of the game, I'll have to find the manual...
EDIT: Apparently you hit F1 to fix my distance problem
Reply 10 of 16, by leileilol
Very out of the question, though VirtualBox + Windows 2000 + zeckensack's glide wrapper would be more in the question
Reply 11 of 16, by DosFreak
DosFreak hits F1 for Wulf.
Reply 12 of 16, by Wulf
Thank you - now I'm fixed (and so is next door's cat).
EDIT: It works, by the way. Best press F1 BEFORE you use Thrust or Brake though, for some reason...
Reply 13 of 16, by RanCorX2
I failed in my xp on usb stick adventure too. I formatted it correctly, setup copied all the files, but upon rebooting for the continuation of setup it bsods on the xp boot screen STOP: 0x0000007B...grrr I'll now give the vbox+2k+glide wrapper a go.
Reply 14 of 16, by RanCorX2
aahhhh gay, rogue squadron on win2k won't let me pick a video card, it keeps complaining that directx isn't installed but it is!! I give up....hopefully the rumored rs trilogy pack for the wii comes out...rumored to include the original game.
Reply 15 of 16, by filipetolhuizen
I could get my demo to work on Windows XP 32 bits using Windows NT4.0 compatibility mode.
Reply 16 of 16, by Davros
Ive certainly had the game running in xp
Edit:
Just tried it and it works although it doesnt detect my glide wrapper
