First post, by benten
Been trying to get my Star Trek 25th CD to work the past few days with some perfect results except for some audio problems.
Game runs smoothly same goes for the music (using Roland LAPC-1 / MT-32 from options) but the sound effects have a hiss and crackle effect of all effects (background, voices, etc)
Using latest Dosbox 0.73 I installed it from both CD and image (dtool) through Dosbox and ran the setup each time to try each sound version. All worked bar the Pro Audios but all the rest still had the hiss/crackle effect.
Settings have changed:
CPU Cycles = 23000 (better running then)
Output = tried all with same results
Fullscreen = both tried
Don't know what else to alter that might fix this problem.
PC Specs also:
MB = Abit P35
CPU = Intel Q6600 - 2.40ghz
RAM = DDR2 4gb
Video = Ati 5850 1024mb gddr3
Sound = Asus Xonar DS
OS = Win7 64bit
Reply 1 of 6, by ADDiCT
Search the forum for posts containing "blocksize" and "prebuffer". Play around with these settings in dosbox.conf and see if it gets better. On my system i'm currently using "blocksize=1024" and "prebuffer=10". Works fine for most games but a few are still giving me audible crackles from time to time (i.e. Magic Carpet).
Reply 2 of 6, by robertmo
try using:
rate=44100
blocksize=1024
prebuffer=20
all other rates 44100 too
also tell us what is your cpu usage when cracking happens
And what do you mean by this: "All worked bar the Pro Audios but all the rest still had the hiss/crackle effect." ??
what is your dosbox version and where have you got it from?
do other games have problems too?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file (also include your MOUNT lines under [autoexec] section)
Reply 3 of 6, by ADDiCT
robertmo, i think i can handle this myself, thank you very much. I'll call you when i need assistance (; .
Reply 4 of 6, by robertmo
what is your Operating System?
what are your PC specifications?
what other games have problems?
Reply 5 of 6, by benten
robertmo wrote:
try using: rate=44100 blocksize=1024 prebuffer=20 all other rates 44100 too […]
try using:
rate=44100
blocksize=1024
prebuffer=20
Those settings worked perfectly thank you and the rest for all the help now can enjoy this game again. Will get more reading on the rates section incase needed for other games now I know where to look thanks to the help given.
For reference
Cpu usage during play is around 7-10%
For the Pro Audio I just tried each audio option in the config to see if any change. All the soundblaster ones worked (but with hiss/crackle) but the Pro Audio made the game not work at all.
Still I'm happy its working perfectly
Reply 6 of 6, by lightmaster
You mean pro audio spectrum? it's not emulated yet.
