First post, by Descention
Alright, so here's the situation:
I installed Descent II through dosbox through a walkthrough on another site, and I did learn a bit of programming in the process (I'm still learning and a bit slow with it) and by the time I tried running Descent II at the end of the process, the dosbox screen went blank.
So, I figured I'd reinstall both dosbox and Descent II to another directory. It didn't take too long, and after going through the setup process again I tried running Descent II a second time and the dosbox screen went blank again.
Now, I don't know what I'm doing wrong and the walkthrough I've been going through has been very helpful but it doesn't have anything on my current problem. I can access the Descent II setup just fine, but everytime I try to run the game, the dosbox screen goes blank and I have to restart. I have another thread on this forum bookmarked but I'm really not sure what other command I need to use, and I'm really anxious to play this game again.
These are the main commands I've been using to get it running:
CDROM E
CD/GAMES/DESCENT2
D2
What else am I missing? Thanks in advance for the help guys!
