First post, by Daqar
Heya,
I've made Mechwarrior 2: 31st Century Combat work in Dosbox 0.73. I'm trying to make MW2: Ghost Bear's Legacy work now. With MW2: 31st CC installed correctly I tried putting the Ghost Bear's Legacy CD in the drive, mount it and run the install. I got an error message from the installer, saying that I need to install from the CD. I then made an iso-file from the CD, mounted that, and ran the installer. This works. But the installer asks me to put in 31st CC cd in the drive. How do I do that?
I tried to mount the 31st CC cd as D:\ and Ghost Bear's Legacy as E:\
The installer doesn't know how to deal with this.
So I need to fx mount the Ghost Bear's Legacy as D:\, start the installer, and then without exiting the installer, mount 31st CC as D:\, and then back to Ghost Bear's Legacy.
How do I do that? Or is there a much easier way of doing this?
If it means anything, I'm using DosBox 0.73 under linux. OpenSuse 11.2 64bit, to be exact.
Best regards,
Daqar
