Ansi C or C++?
First post, by Zirias
Hi,
I just wanted to do some little modifications and was quite surprised to find only plain old C code in the .cpp files. Is there a particular reason for using a C++ compiler (along with libstdc++ et al)?
edit: I just discovered openglide INDEED compiles fine using gcc (and NOT g++), so there's definitely no c++ code anywhere. This helps me build a i386 version on my amd64 host right now, because my debian environment doesn't provide ia32 libstdc++ import library ATM.
So, why is all the code in .cpp files? Is this for building in microsoft visual studio, that doesn't provide a plain C compiler but only C++? If so, wouldn't setting CXX="gcc" on any GNU environment by default be a good idea?
Reply 1 of 15, by MattRocks
Anecdotal evidence only, but when I worked with C and C++ in large organisations the developers did strange things because they were more constrained by policies and working conditions.
Some employers had offline development environments, banned stack exchange, and decisions were made in closed rooms with small scrum teams operating to aggressive time frames.
It would be common to hear disputes over which compiler was better for debugging, produced more optimised code, etc. The decision would be made in the ceremony under vote if necessary.
Similar things happened in more public projects too. I remember being banned from one forum because my opening post was on translating some PHP into Perl.
I later discovered their lead engineer had left the organisation and launch a rival PHP version of an existing Perl product, the old injured organisation was tense, and I asked the wrong question at the wrong time.
So it’s quite believable that OpenGlide adopted C on g++ to pamper a momentary ego that nobody wants to talk about.
Hope that helps? 😀
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i7) ] * lost
Reply 2 of 15, by jmarsh
OP hasn't been active since 2017 and posted this question 7 years before that. I doubt they've been waiting for someone to guess an answer.
Reply 3 of 15, by Errius
C is valid C++ so why wouldn't you use a C++ compiler
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 4 of 15, by MagefromAntares
Errius wrote on 2026-05-09, 07:45:
While this is mostly true, yes most C is valid C++, but there are slight differences, for example C lets you convert void pointers to other kind of pointers without explicit conversion:
Valid C but invalid C++ code:
char* somedata = malloc(size);
This will fail on C++ compilers because they don't convert void pointers automatically to other types, and some kind of cast needs to be used to convert the result.
"A process cannot be understood by stopping it. Understanding must move with the flow of the process, must join it and flow with it." - Dune
Reply 5 of 15, by wbahnassi
Pure C code in .cpp extension is not right, and there are no reasons related to Visual Studio that push people to such confusing file naming. The Microsoft compiler can be forced to compile C and error out on C++ regardless of file extension, but IIRC it does that automatically with files of .c extension.. so just name the files properly to first let people know which language to use, and second have the toolchain do the right thing.
Now the choice of whether to allow some C++ in C is something else that is really up to the taste of the project owner. Each have their way...
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 6 of 15, by Errius
Does this compile in your C++ compilers
wmain( argc, argv )
int argc;
wchar_t **argv;
wprintf( L"Hello World\n");
Reply 7 of 15, by jakethompson1
For a long time Microsoft's philosophy was that C++ replaced C. The C compiler that was activated in Visual Studio when compiling a .c file was frozen in time with C89/C90 features.
The C99 article on Wikipedia has a few instructive references. Here is one from 2012 showing that Microsoft philosophy: https://www.infoq.com/news/2012/05/vs_c99_support/
Since then, they had a change of heart, and the compiler for .C files in Visual Studio has been substantially upgraded in VS 2013 and later.
But because of this legacy, Windows developers often write "C++" that is little more than C with a few C++ features that were later backported to C99. Namely, begin able to declare fresh variables in a for statement, and being able to declare a variable anywhere in a function rather than only at the top of a block.
The UNIX-Haters Handbook has a humorous take on the situation:
Fortunately, most good programmers know that they can avoid C++ by writing largely in C, steering clear of most of the ridiculous fea- tures that they’ll probably never understand anyway. Usually, this means writing their own non-object-oriented tools to get just the features they need. Of course, this means their code will be idiosyncratic, incompatible, and impossible to understand or reuse. But a thin veneer of C++ here and there is just enough to fool managers into approving their projects.
People who actually like C++ will tell you that these criticisms are outdated and don't apply to "modern C++," that is, using a C++11 compliant compiler and purging any third party libraries that are non-modern C++.
Reply 8 of 15, by jakethompson1
An even simpler example than the one MagefromAntares gave is that C++ has more reserved words than C, e.g. int class; is valid C but not C++. That might seem silly, but it might come up in C code that parses or otherwise deals with C++ or other object oriented languages. Java's reflection and JNI features run into the same problem, which they handle by deliberately misspelling class as clazz when naming a variable.
Reply 9 of 15, by MagefromAntares
Errius wrote on 2026-05-09, 20:56:
Does this compile in your C++ compilers […]
wmain( argc, argv )
int argc;
wchar_t **argv;
This doesn't even compile even on K&R compatible C compilers, you are missing the
#include <wchar.h>
at the beginning 😁
Nice Cobra MK III avatar from Elite though 😀
Reply 10 of 15, by mr.cat
Hmm. I'm confused as to what codebase OP was looking at.
Because the code in OpenGlide (the original OpenGLide_008_src.zip from sourceforge) sure looks like C++ to me.
Granted it's in old style, so quite C-like, but there are things such as "new" and "class" in there.
And ofc the most obvious thing, the C++ style comments (gcc will gladly accept these by default though).
EDIT: Thank you. TIL 😁
vvvvvvvvvvvvvvvvvvvv
Reply 11 of 15, by MagefromAntares
mr.cat wrote on 2026-05-10, 11:26:
Hmm. I'm confused as to what codebase OP was looking at. […]
I have checked the source at https://github.com/fcbarros/openglide# as the project says https://sourceforge.net/projects/openglide/ that is now the official repository.
C supports C++ style comments since C99, so that is not weird.
But the new and the class keywords are not officially supported by any of the current C standards.
But the build system might have realized that gcc was being run on a C++ file, and added the extra command line parameter
gcc -x c++
this makes the gcc compiler defer to g++ when it encounters C++ code.
Reply 12 of 15, by SiBurning
sizeof('c'); // might be different
char *s = "duck"; // illegal in C++
s[0] = 'f'; // undefined behavior in C
uninitialized global variables are shared in C but are illegal in C++. (Why?) This linkage issue is probably the most notorious difference, and lord help you if you link both types of files into a single binary. This is a serious problem in some APIs (::cough:: ODBC ::cough::). When I interview people, I always ask about callbacks in ODBC related to bits, endian, sizeof, and casts, and the stupid clash between typedefs and # definitions in C vs C++, and as I mentioned above, you can easily have different API definitions in the same binary. And, no. Not one person was ever able to explain more than 1/4 of it. (hint: Did I mention AIX? Or how about short vs long pointers?)
Reply 13 of 15, by MattRocks
SiBurning wrote on 2026-05-11, 01:00:
sizeof('c'); // might be different char *s = "duck"; // illegal in C++ s[0] = 'f'; // undefined behavior in C […]
You're giving me nightmares and I haven't slept yet.
Reply 14 of 15, by SiBurning
The question is deceptively simple. Or should be for developers with years of experience. The cross-platform API has a function that takes several parameters, one to data, the other to to a callback function. All of them are HANDLE type things. When it calls your function, the formal parameters are also HANDLE types of things. Then I ask, how do you get it to work across platforms with different bit sizes and endian. And we start the conversion to see what they know. You pass if you can discuss two of the problems without sounding clueless. That's discuss intelligently in a conversation, not even explain everything offhand. It's a big, low level exploration for a discussion, with me giving small clues slowly. And a disappointing mess for many.
It occurs to me that a lot of Vogons would do way better than those guys, who probably couldn't tell me in which order the bits of a byte are arranged in physical memory. 😉
I just noticed... this thread is not only 15 years out of date, but no longer has anything to do with Glide. We should probably move it to Stack Exchange. 😀
Reply 15 of 15, by MattRocks
I see, ints and chars. You just need to make it distributed, so that every app is correct but the same undefined behaviours emerge when the apps communicate with each other.
It fixes itself once Google associates your tests with redirections, Meta connects the tests to the real identity of someone else, and ChatGPT uses the insights to devise Trump's next military strategy.
And that's why more and more people will be trying to make Glide work on hardware it was never intended to run on - like ostriches and sand holes, we all need a coping strategy! 😉
