First post, by frero
Hello,
I 've just downloaded dobofro (dos box frontend) and I don't know how to use it.
Example, I have conquest of longbow in : g:\frero\documents\robin
I have dobofro in g:\frero\documents\dosbox
I selected my file to start as g:\frero\documents\robin\sierra.bat
and click on start button of dobofro.... then at the lower side of my screen, I have a message : "opening g:\frero\document\sierra.bat etc... and dosbox -c etc...
but nothing happens ??
In the zip file, I have juste a .txt document which explain that we can use dosbox directlu (without dobofro) but we have to write:
Mount c: etc... etc.. but my hard disk is the g: and not the c: what I have to to in order that dosbox let me play with conquest of longbow without problems ... 🙁
I 've already tryied to put a gosierra programm to run sierra games better, but nothing change.....
Thanks a lot
Frero
Reply 1 of 6, by frero
I ve forgot that my PC is under XP -pro and is an AMD athlon 2400+ with sound integrated on my motherboard....
thanks again
Reply 2 of 6, by TheSeeker
without using the front end, you can launch dosbox, then type:
mount c g:\frero\documents\robin
This will cause the virtual machine to see g:\frero\documents\robin as c:\
next you would go:
c: <enter>
sierra.bat <enter>
Reply 3 of 6, by frero
thanks so much for your answer 😀
Reply 4 of 6, by frero
Hum hum.... 🙁 I just come back from the tests of your advice.... but it does not work. In fact, my windows is on the c: but my dos box directory with robin is on the g: when I start dosbox I have a Z: SO I tried mount c g:\frero etc... and it say "g: does not exist" I ve tried mount z z: "z: does not existe ...
Should I install dosbox in the main tree c: (with my exploitation system ??) or it is sur that dosbx works if it is installed in another directory ???
Thank for all
Reply 5 of 6, by eL_PuSHeR
Is G: a CD-ROM/DVD drive by chance?
Try this:
mount g g:\ -t cdrom
and then enter g: to go to it and use the ms-dos command CD to change directory if needed. Example: cd install
P.S: I usually tend to match real drive letters with their DOSBox counterparts. This way, I avoid confussion.
Reply 6 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
frero wrote:
Hum hum.... :( I just come back from the tests of your advice.... but it does not work. In fact, my windows is on the c: but […]
Thank for all
I think you did it the wrong way around
mount driveindosbox driveinwindows
so mount g c:\
would mount your windows drive c:\ in dosbox as g:\
Water flows down the stream
