First post, by xXephis
Hi folks,
i noticed, that DosBOX with --enable-debug flag crashes, if started in small windows.
It just exits without reseting terminal and prints "Segmentation Fault.".
Is that a bug or a feature? 😉
Working on Linux EeePC 2.6.32-020632-generic #020632 SMP Thu Dec 3 10:58:45 UTC 2009 i686 GNU/Linux. (Ubuntu Netbookedition with patched kernel -> 2.6.32)
cu
Reply 1 of 7, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
What does the term 'small windows' refer to?
1+1=10
Reply 2 of 7, by xXephis
Sorry,
i mean a 'small' gnome-terminal with (e.g.) 30 lines and 80 cols..
not "windows".
Reply 3 of 7, by wd
Rank DOSBox Author
DOSBox Author
It works without the debug configure flag?
Reply 4 of 7, by xXephis
I haven't tried to compile without debug,
but i guess the error is issued by the debug-screen,
because the original ubuntu-package works fine.
(downloaded the source with 'sudo apt-get source dosbox', configured with --enable-debug, compiled it and installed with 'make install')
However, i will start dosbox in 'maximized' terminals
and with a bigger resolution (1024x768 instead of [eeepc original] 1024x600).
By the way, i noticed this issue in 0.73 and 0.74.
hth
Reply 5 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
try xterm instead of gnometerminal which doesn't support resizing of the terminal. (which is a normal console command)
Water flows down the stream
Reply 6 of 7, by xXephis
solved the problem 😀 ty
Reply 7 of 7, by raMASTER
same problem in urxvt (shell/terminal).
just in case somebody searches for this.
