Harddrive problems
First post, by blubba
When i start dosbox, he generates a virtual drive z:\. but i can enter my drive c:\(slave) or drive g:\(master and systemdrive).
Please help!!
Reply 1 of 1, by eL_PuSHeR
You have to mount at least a drive to be able to use DOSBox. For example: MOUNT C C:\ will mount your C drive as C:
MOUNT F F:\ -t cdrom will mount the CD-ROM drive F as F:
Then use the C: or F: commands to change drives and cd directory-name to change directories.
