First post, by Pretzel77
Hi, and thanks for reading, I am kinda new to this emulation stuff, and am wanting\trying to play the original lemmings game again, i've got the game, a couple of versions apparantly, and also dosbox 7.2, and just now, tried 7.4. I can mount the directory fine, and start the game with vgalemmi.exe, but as soon as a level starts, and I touch the mouse, it scrolls to the left of screen, and stays there regardless, I can unlock it doing the ctrl-F10, but this doesn't help with using the mouse for gameplay, i've done some searching, and can't really find an answer for this?, oh, i'm on vista btw...
Reply 1 of 4, by robertmo
have you red the manual?
Reply 2 of 4, by TomJeffersonJones
Does this version of Lemmings have joystick support? If so, do you have a controller/stick of some kind plugged into your PC? If so, maybe you need to run the game's calibration routine, disable the stick in the game's options/installer, or shut down dosbox's joystick emulation.
Reply 3 of 4, by Wulf
I have Lemmings 2 and had exactly this problem, and, yes, it was the joystick - as I didn't want to use it, I unplugged it and the game works fine.
Reply 4 of 4, by eL_PuSHeR
I remember the original Lemmings was run from a batch file with configuration parameters after you set up the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
